I am trying to make a 11.4 mile link at 5.8 GHz. I have two dish antennas rated at 23 dB, will be using LMR600 cables probably no longer than 10 feet on RX side, and 40 feet on TX side. I am using an Atheros card rated (from my understanding) at 65mW. I clear the required Fresnel zone easily, but I can’t find any calculators (that I can understand anyway) that can help me gain an idea of what dB I can expect on each side at the fastest allowable speed. Can anyone recommend a good RF calculator? Next on the docket, should I need a boost, I have a few choices - better card, better antennas, and amplifier. Of these choices, I’m trying (of course) for the lowest priced, but most reliable… a happy medium. Any words of wisdom (with the founding reasons, of course - no blind leading the blind please) are very much appreciated. Thank you!
Brad
