RG750 as a switch in a LAN
Hello everyone!
I am interested if a RG750 can be used as a switch in an existing LAN. I was thinking to use eth1 as a management port and the ports from eth2 to eth5 as a switch. The idea would be to create some queues to prioritize the traffic through the switch.
Thank you.
This is the default settings.
The computers connected to the switched ports of the RB750 will be in the same LAN as those connected outside the RB750?
I’m not sure what you mean, but you can disable NAT and use it like a switch to prioritize the traffic.
http://wiki.mikrotik.com/wiki/Switch_Chip_Features
http://wiki.mikrotik.com/wiki/Manual:Queue
Hello.
Thanks for the tip with NAT. It was the missing link. I managed to make it work by using a bridge with IP firewall turned on. As I understand (basic networking knowledge), you cannot mark switched packages.
Thanks again.
