RIC522 max link distance
What’s the max link distance/throughput point to point attainable with a couple of RIC522T or RIC522C (with miniPCI R52) ?
I have reached 30 Mbps/UDP 20 Mbps/TCP on 8 km point to point link.
It is possible to reach 15/20 km link with at least 10/15 Mbps trhoughput ? (obviously with perfect fresnel / LOS)
BY - oveda
It’s possible with the R52H or XR5 cards, I didn’t calculate the R52. You need good antennas and short runs between the cards and antennas. Don’t stack on three adapters, two right angles, and a couple of lightning arrestors and expect miracles.
Hi, i’m use 522 in link point to point 15km without problem with not less 25mts tower hight.
Heri
Interesting..
And.. CCQ and Signal strenght ?
bye - oveda
Hi oveda it’s me mushmx
Signal strenght = 72/78
mb transfer= 24/36
does you link have a line of sight? coz is very important
Heri
Yes, I have perfect LOS.
Now I want to try this link (15 -17 - 19 km - with R52 and with R52H)
Bye - oveda
Hi again
The 522 is perfect to 15km but more, if you need do a link up 15km you should use a routerboard 532 “wireless card R52H” with antenna heavy duty like 28dbi.
Best Regard.
mmm, next week I’m having good exeperience with Ric522 + r52 + R52H
I will make you know the result.
bye oveda
