right product?
hi, i’m new from here…
i wonna ask you if this product http://www.mikrotik.com/pdf/rb_rpo.pdf is compatible with my wisp.
they says me than they use the hyperlan (5ghz) tecnology to provide the internet connection on the houses and factory with hotspot’s mikrotik routerboard…
So, if i buy this Kit, can i connect on these? or i need other thinks? i seem that’s all in the kit
any suggest or question, i’m here
p.s. all my apologies 4 my english… :laughing: :laughing: :sunglasses:
Hy.
If your provider use some Hyperlan/2 proprietary technologies, such as TDM on Alvarion (or Canopy or something else), you are unable to connect this to him.
The problem of Hyperlan, is that there are a lot of (uncompatible) proprietary standard on the market, such as “nstreme” from Mikrotik.
But, if you are sure that they use Mikrotik RouterOS for the client side, this product is perfect for you.
Pay attention to the country law imposition!!!
On Italy, for example, max permitted EIRP is 1W (30dBm), and on the product you linked here there’s a 30dBi antenna, so you have to set frequency-mode=manual-txpower, and retrieve 3dBm max from your card (i assume 3dB cable loss), or you will be outlaw!
P.S.
Guarda chi si vede…tana! :wink:
yeah, they use mikrotik’s routerboard in their hotspot…
intead, for the law question, i don’t care… (it’s not illegal, trust) :wink:
just another question… Can I buy only the dish Antenna without rb and other? I need a 5ghz dish Antenna for another installation
P.S. ti avevo già beccato io… :wink: come facciamo a scambiarci la posta elettronica?
thx to all!
I don’t know, but i think that it is not possible.
Vai su qrz.com e ricerca il mio nominativo radioamatoriale (che trovi in firma nei miei post su wireless italia). Dimmi se hai problemi a trovare il tutto.
facciamo invece che vai su elitweb.it e trovi mio nick e ci sentiamo per posta elettronica, ok? …altrimenti con skype
Ok, fatto.
Sorry for italian language here.
