The attached PDF document describes a comprehensive QoS / Traffic Shaping implementation for RingCentral UCaaS services. The configuration can be copied and pasted into a terminal window.
It can be easily expanded or modified to support other cloud services. Please let me know of any corrections or improvements!
July 13, 2021 - Edited to improve rule placement logic and misc text edits per ‘rextended’.
July 13, 2021 - Added word version - copy and paste should be done from Word version as copy and paste from PDF creates issues.
July 13, 2021 - Tested against v7.1b6 with no obvious issues.
I suggest to:
use an editor and replace all case-insensitive occurence of Kbps to kbps
use an editor and replace all case-insensitive occurence of mbps to Mbps
use an editor and replace all case-insensitive occurence of QoS class to QoS Class or QoS class how you like, but the same name everytime…
then correct the scripts
use “k” for kilobit instead of “K”
use “M” for Megabit instead of “m”
then the method of move with “place-before=*0” broke some default / dynamic rules on RouterOS already present on mangle (when used obviously)
must be used one better methods like place-before=([find where dynamic=no]->0) or more better leave the user to move the rules on top, on right place.
Then the pdf when copied do not copy line-return causing a mess with copied text
The MIkrotik devices form my favorite toolbox item… You can do/simulate almost anything with them for development and they work very well in production.
I tested the VoIP setup as much as possible without having high volume call simulation equipment. Anyone running high volumes of call please let me know if you encounter any problems!
