We recently upgraded to 2.9.46 from 2.9.39
Everything seems to be working except one connected route is not being advertised by RIP.
I can’t seem to get it to work.
Our route list shows about 20 connected routes, I have set RIP to redistribute connected.
All of them except one route is being redistributed, has anyone run into this problem ?
What is your RIP configuration, do you have any filter configured ?
What do you see at the logs, when “rip, debug” logs enabled ?
Make sure you are using ‘routing-test’ package on MikroTik routers.
‘routing-test’ includes the latest feature for the routing.
Make sure that ‘routing’ configuration is correct on both sides, as I have tested 2.9.46 (routing-test) with Cisco RIP, there were not any problems.
Default configuration on both sides should work fine. Report back with the export of the configuration, if you encounter any problems.
