RIP ROUTING PROBLEM
I have what I believe is a fairly simple setup. I am planning to replace other routers (non-Microtik) one at a time and I am configuring these to match their settings nearly identically. The routers are running RIPv1 w/o authentication.
I currently have two RB1100’s (tried with shipped 4.16, 4.17, 5.0r7) plugged into eachother directly. Router A has ether3 (192.168.105.1/24) connected to Router B’s ether2 (192.168.105.2/24).
I originally started configuring with winbox, and have since been referring to http://www.mikrotik.com/testdocs/ros/2.9/routing/rip.php however I am not seeing any issues on my configuration, just rather I’m not seeing the routes or neighbors.
I have tried manually adding the routes to the 192.168.105/24 networks as static routes, then they are able to ping each other without specifying the interface, I have also tried adding the neighbors. In both cases, they are not exchanging routes. The RIP Traffic does however increment.
Any solution ?
Still no reply…
That you can’t ping the directly connected router unless you specifically specify an interface indicates that something far more fundamental is wrong. Let’s fix that first.
Can you post the output of just “/ip address print detail”, “/ip route print detail”, and “/interface ethernet print detail” from both routers, wrapping the output in
 tags when you post it so it stays readable?
Router A:
[admin@MikroTik] > /ip address print detail
 0   address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255
     interface=WAN actual-interface=WAN
 1   address=10.10.1.1/24 network=10.10.1.0 broadcast=10.10.1.255 interface=LAN
     actual-interface=LAN
[admin@MikroTik] > /ip route print detail
C - connect, S - static, r - rip, b - bgp, o - ospf
 0 ADC dst-address=10.10.1.0/24 pref-src=10.10.1.1 interface=LAN scope=10
       target-scope=0
 1 ADr dst-address=20.20.1.0/24 gateway=10.10.1.3 interface=LAN
       gateway-state=reachable scope=20 target-scope=10
 2 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.2 interface=WAN scope=10
       target-scope=0
admin@MikroTik] > /interface ethernet print detail
 0  R name="WAN" mtu=1500 mac-address=00:03:FF:A4:31:55 arp=enabled
      disable-running-check=yes auto-negotiation=yes full-duplex=yes
      cable-settings=default speed=100Mbps
 1  R name="LAN" mtu=1500 mac-address=00:03:FF:A5:31:55 arp=enabled
Router B:
 0   address=20.20.1.1/24 network=20.20.1.0 broadcast=20.20.1.255
     interface=ether2 actual-interface=ether2
 1   address=10.10.1.3/24 network=10.10.1.0 broadcast=10.10.1.255
     interface=ether1 actual-interface=ether1
 0 ADC  dst-address=10.10.1.0/24 pref-src=10.10.1.3 gateway=ether1
        gateway-status=ether1 reachable distance=0 scope=10
 1 ADC  dst-address=20.20.1.0/24 pref-src=20.20.1.1 gateway=ether2
        gateway-status=ether2 reachable distance=0 scope=10
 2 ADr  dst-address=192.168.1.0/24 gateway=10.10.1.1
        gateway-status=10.10.1.1 reachable ether1 distance=120 scope=20
        target-scope=10 route-tag=0
[admin@MikroTik] > /interface ethernet print detail
Flags: X - disabled, R - running, S - slave
 0 R  name="ether1" mtu=1500 mac-address=00:03:FF:A2:31:56 arp=enabled
 1 R  name="ether2" mtu=1500 mac-address=00:03:FF:A3:31:56 arp=enabled
