Good night,
I’m using Mikrotik chr-6.48.3 version to establish a GRE tunnel over IPsec. And inside the GRE tunnel, I want to use the RIPv2 protocol, but I don’t want the “main” routing table to be used, but another separate routing table.
When I change in “RIP Settings” the routing table name to a new name, for example “teste” and apply settings, all my RIP routes disappear and there are no RIP messages. I’ve already restarted the routers. However when I change the routing table name to “main” again, RIP works normally.
Could it be a bug? I want to have the RIP routes in a separate routing table.
Any help, I appreciate it.
