RIP setup
Please help! Hi, I need help to setup routing throw RIP, cause I’ve two Public interfaces, 2 real IP for Public LAN and internal LAN work on Masqurading. The Public IP adresses are from one range and have the same gateway. What I need to do let router by itself change routing to second channel when first is full? Thank You.
you need load balancing. RIP will no do that for you
Yes I need it but with the same subnet it doesn’t work. MT sees only one WAN, but if enable second WAN it doesn’t work at all, it doesn’t know where put the traffic to WAN1 or WAN2 and work Skype only other ports doesn’t work.
Having the same gateway for both WAN links leaves you dea in the water right now. You would need a feature calles “interface based routing”, which is still not available in RouterOS.
Your only option is to put one dedicated router in front of every uplink and use transfer subnets between those routers and your main router.
Best regards,
Christian Meis
But if put in one uplink SOHO router and the second throw to MT router, will it works?
It should, yes…
And this would be the right time for you to ask MikroTik for interface based routing :smiley:
One more voice for it…
Best regards,
Christian Meis
Ok.
Thank You a lot.
