Hi guys,
I would like to find out, can the RJ45 console port on the newer Routerboard models be used for something like reverse telnet to other devices?
I know the serial interfaces can do it, but isn’t the RJ45 port almost like a serial interface?
Thanks!
This port is identical to regular serial console port on other RouterBOARD devices, it can do the same things, and to software, it looks just like normal serial port.
Awesome, Thanks Normis!
I just wanted to check to be absolutely sure.
