Hi, I’m looking for RJ45 plugs with grounding. I can’t find them anywhere. does anyone know where i can order some?
thx.
Peter.
did you try pacwireless
http://www.pacwireless.com/products/RJ45-ECS.shtml
I am using
them for a long time. very good. it uses ftp cable with grounded plugs.
that’s Not what I’m looking. I just need the RJ45 connector that you crimp on an ethernet cable, but i want those that have the metal shielding for ground.
Stranded CAT5
http://www.milestek.com/shop/product.asp?id=10%2023083&cid=&kwd=&l=&p=
Solid CAT5
http://www.milestek.com/shop/product.asp?id=10%2023066&cid=&kwd=&l=&p=
Hope that helps.
Nate
