RM version of netPower 16P
Hi Mikrotik team,
Why isn’t there a rack mountable version of netPower 16P?
I think it would be useful.
Thanks’,
Geo
Because it is easy to make one yourself if needed?
JFYI:
http://forum.mikrotik.com/t/suggestions-for-netpower-16p-wall-mounting/183861/1
I meant the installation in a 19" network rack, not in an electrical rack on the DIN rail. That way I can attach the switch with a wire to an internal pole.
I see, now :slight_smile: .
I think the idea is to sell the faster (but almost double the price) CRS328-24P-4S+RM:
https://mikrotik.com/product/crs328_24p_4s_rm
I believe the netpower can still be modified with some clever work with a hack saw, see starting from here:
http://forum.mikrotik.com/t/switch-in-rb509-l009-formfactor/180421/1
In any case it will take 2U, possibly 3U if you want to allow some more circulation of air to the heatsinks (which become horizontal).
One potential issue with the NetPower 16 is that it does not have any fans. Thus if you mount it in a horizontal ( flat ) position in a rack where the rack is in a remote tower location without air conditioners ( cooling ) , the NetPower 16 may run hotter because of less cooling.
The NetPower 16 was designed to be mounted outdoors in a vertical position , which then permits better cooling.
One of the custom modifications I have done is to modify a Mikrotik rackmount PoE router/switch to operate on DC instead of AC.
Example , I have several Mikrotik 24-Port CRS328-24P-4S+ and Mikrotik 48-Port CRS354-48P-4S+2Q+RM ( PoE ports to power my APs ) I have modified.
These Mikrotik PoE CRS rack mounted routers/switches have fans.
It’s pretty easy to remove the internal AC power supplies and connect all of the internal motherboard power supply wires/connectors ( grounds , commons , +24 Volt and +48 Volt ) to an external DC connector where the AC connector was mounted. Then make a cable that runs from a battery backup DC UPS ( ALG DC-UPS +24 Volt and a second optional ALG DC-UPS +48 Volt ) to your DC modified Mikrotik CRS.
I have several DC modified Mikrotik CRS PoE routers/switches at most of my remote towers for several years now. None of them have ever had a problem.
For my external batteries , I use two or four 12 Volt truck batteries connected to my ALG DC-UPS power supplies.
This setup is far far far more efficient than a 120 Volt UPS. Also no tower located generators are needed. I can run about a week or more on battery power , and when the AC utility power is restored , the external batteries will fully recharge. This completely eliminates the need for a generator and no more trips to a remote deep snow covered mountain top tower to replenish fuel.
I have posted multiple times in these Mikrotik forums how I modified my Mikrotik CRS routers/switches and included pictures. Search the forums and you can find them.
** I wish Mikrotik would come out with an optional simple cable harness for their CRS routers/switches ( the AC powered routers/switches that include a “P-” in their model name ) - to make it super easy for others to do the same.
If you are like me , you have and use the PoE watchdog to auto power-cycle your tower APs when they stop communicating. And all of your remote APs and routers/switches have DC power to enable you to operate weeks or more when the power goes out - and not have to worry about will the generator start and when/how do I get generator fuel there during a disaster. Also , no worry about how long a 120 Volt UPS will last on battery power and are those tiny UPS batteries still good.
North Idaho Tom Jones
