RM1100AHx2 PPPoE service entry stops it working
I have an RB1100AHx2 that has been replaced by a AHx4 so decided to use the AHx2 for my local router, I have set up PPPoE connection and it works fine until I enter the service, I have 3 ranges of IP’s and I use the service entry to assign IP’s from the different ranges using radius via the AHx4 router and it works on all the routers I have tried so far that my customers use.
I does not work on the AHx2, I get access denied in the radius server log, all I have done is enter the service name which in this case is service3, if I remove the service and reboot it works OK
any idea what is wrong
