Roaming aggressiveness/sensitivity for AR9580
Hi guys,
I recently bought one R11e-2HnD AR9580 and R11e-2HPnD AR9580 wifi adapter. I wanted to compare the performance of both in Advantech. I am using windows 7 in Advantech and installed driver version 10.0.0.328. However i was not able to see the roaming aggressiveness options in the device manager properties menu. It was also interesting to see that none of the LED lights on the wireless adapter has been turned on. Should i install anything other than the driver? Any kind of help will be much appreciated :slight_smile:
