Roaming between ap's or ports on Mikrotik disables access for x minutes
Hey
My problem is most likely simple but i have not been able to solve it.
First of all i have tested it in 2 ways.
First if i have 1 laptop and connect it to 1 port. it gets dhcp ip and everything and if i then moves it to port 2 this computer will not have any access for x amount of minutes.
The same happens when i use my Unify aps conected. If i roam between them i loose the connection for x amount of time and im not sure how to solve this.
its connected like this:
ap1 ---- <miktorik 1> —[vlan trunk]–<mikrotik 2>–ap2
(To make this easier i have also connected both AP on mikrotik 2 and same fenomenom.
So when i roam between above 2 aps i loose connection for X amount of time.
I have been looking into STP RSTP but that didnt seem to solve it.
Tips on where to look? Do you need the configs?
