Roaming Identity
Hello
I try to setup a little wpa-enterprise environment. My problem is same as: link
When I write something in the “Roaming Identity” under Intel Pro WIFI set or Linux the user-name in the radacct sql table is not equal to the radcheck user-name but the postauth user-name is correct. I try this solution, but not working. The MT is 3.3 and the freeradius is 2.1. Have you got an idea?
Thx
Miki
