I am getting more and more frustrated with the random disconnects:
This is the config (I took out a bunch of access list entries and scripts to make it easier to evaluate):
# 2024-11-25 16:42:55 by RouterOS 7.16.1
# software id = 5NRD-V1QF
# model = C53UiG+5HPaxD2HPaxD
# serial number = HDG0
/interface bridge add admin-mac=48:A9:8A:0F:04:8F auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface bridge add admin-mac=4A:A9:8A:0F:04:94 auto-mac=no name=bridge-guestwifi
/interface ethernet set [ find default-name=ether1 ] comment="To RB5009" poe-out=off
/interface ethernet set [ find default-name=ether3 ] comment=TV
/interface ethernet set [ find default-name=ether4 ] comment=TV
/interface wifi set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=all .width=20/40/80mhz configuration.antenna-gain=0 .country=Russia .mode=ap .ssid=Upstairs5g-0F0493 .tx-power=16 disabled=no security.authentication-types=wpa2-psk .disable-pmkid=yes .ft=yes .ft-over-ds=yes .management-protection=disabled .passphrase=XXXXX
/interface wifi set [ find default-name=wifi2 ] channel.band=2ghz-g .skip-dfs-channels=disabled .width=20mhz configuration.country="United States" .mode=ap .ssid=Upstairs-2G-0F0494 disabled=no security.authentication-types=wpa2-psk .disable-pmkid=yes .ft=yes .ft-over-ds=yes .management-protection=disabled .passphrase=XXXXX
/interface eoip add disabled=yes mac-address=02:88:47:EE:7A:47 name=eoip-tunnel-to-212-rb5009 remote-address=XXXXXXnnel-id=101
/interface wifi add configuration.mode=ap .ssid=2point4 disabled=no mac-address=4A:A9:8A:0F:04:93 master-interface=wifi2 mtu=1500 name=2point4 security.authentication-types=wpa2-psk .disable-pmkid=yes .ft=yes .ft-over-ds=yes .management-protection=disabled .passphrase=XXXXX
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/interface list add include=all name=TRUSTED
/interface wifi configuration add datapath.client-isolation=yes disabled=no name=guestcfg security.authentication-types=wpa2-psk .disable-pmkid=yes .ft=yes .ft-over-ds=yes .passphrase=blueberry ssid=GuestWifi
/interface wifi add configuration=guestcfg configuration.mode=ap mac-address=4A:A9:8A:0F:04:94 master-interface=wifi2 name=Guest2g security.management-protection=disabled
/interface wifi add configuration=guestcfg configuration.mode=ap disabled=no mac-address=4A:A9:8A:0F:04:95 master-interface=wifi1 name=Guest5g security.management-protection=disabled
/ip pool add name=pool-guest ranges=10.0.0.10-10.0.0.252
/ip smb users set [ find default=yes ] disabled=yes
/queue type add fq-codel-interval=60ms fq-codel-limit=800 kind=fq-codel name=fq
/system logging action set 3 remote=192.168.0.13 syslog-severity=emergency
/system logging action add name=logserver remote=192.168.0.112 remote-port=51400 target=remote
/system logging action add name=Graylog remote=192.168.0.147 syslog-severity=emergency target=remote
/interface bridge port add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf interface=*6 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge interface=ether1 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge interface=2point4 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge interface=wifi1
/interface bridge port add bridge=bridge-guestwifi interface=Guest2g
/interface bridge port add bridge=bridge-guestwifi interface=Guest5g
/ip firewall connection tracking set udp-timeout=10s
/ip neighbor discovery-settings set discover-interface-list=TRUSTED
/interface bridge vlan add bridge=bridge disabled=yes vlan-ids=100
/interface list member add comment=defconf interface=bridge list=LAN
/interface list member add comment=defconf interface=ether1 list=WAN
/interface list member add interface=bridge list=TRUSTED
/interface list member add interface=ether1 list=TRUSTED
/interface list member add interface=*6 list=TRUSTED
/interface list member add interface=wifi2 list=TRUSTED
/ip address add address=192.168.2.5/24 comment=defconf interface=bridge network=192.168.2.0
/ip address add address=10.10.10.5/24 disabled=yes interface=bridge network=10.10.10.0
/ip address add address=172.16.0.1/24 disabled=yes interface=*C network=172.16.0.0
/ip address add address=10.0.0.1/24 interface=bridge-guestwifi network=10.0.0.0
/ip address add address=10.0.0.1/24 disabled=yes interface=Guest5g network=10.0.0.0
/ip cloud set ddns-enabled=yes
/ip dhcp-server add address-pool=pool-guest interface=bridge-guestwifi name=dhcp-guestwifi
/ip dhcp-server add address-pool=pool-guest disabled=yes interface=Guest5g name=dhcp-guest5g
/ip dhcp-server network add address=10.0.0.0/24 dns-server=1.1.1.1 gateway=10.0.0.1
/ip dns set allow-remote-requests=yes cache-max-ttl=4w cache-size=32768KiB query-server-timeout=5s servers=1.1.1.1,8.8.8.8,9.9.9.9,8.8.4.4
/ip dns static add address=192.168.2.5 comment=defconf name=hapax3.212.local type=A
/ip dns static add address=10.0.0.1 comment=defconf name=router.lan type=A
/ip firewall address-list add address=10.0.0.2-10.0.0.254 list="Guest WiFi"
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=accept chain=input comment="allow 67 68 to 10.0.0.1" dst-address=10.0.0.1 dst-port=67,68 log-prefix="allow 67 68 to 10.0.0.1" protocol=udp
/ip firewall filter add action=drop chain=input comment="drop all to 10.0.0.1" dst-address=10.0.0.1 in-interface=!lo log=yes log-prefix="drop all to 10.0.0.1"
/ip firewall filter add action=drop chain=forward comment="drop all 10.0.0.0/24 to not-WAN" disabled=yes log=yes log-prefix=drop-all-10-0-0-0-24-to-not-WAN out-interface-list=!WAN src-address=10.0.0.0/24
/ip firewall filter add action=drop chain=forward comment="drop guest to 192.168.0.0/16" dst-address=192.168.0.0/16 dst-port=!53,68,68 log=yes log-prefix=drop-guest-to-192-168-0-0-16 protocol=udp src-address-list="Guest WiFi"
/ip firewall filter add action=accept chain=forward
/ip firewall filter add action=accept chain=input disabled=yes
/ip firewall filter add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
/ip firewall filter add action=accept chain=forward disabled=yes in-interface-list=LAN log=yes
/ip firewall filter add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes hw-offload=yes
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked disabled=yes
/ip firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
/ip ipsec profile set [ find default=yes ] dpd-interval=2m dpd-maximum-failures=5
/ip kid-control add fri=0s-1d mon=0s-1d name=Monitor sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d wed=0s-1d
/ip route add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service set www-ssl disabled=no
/ip smb shares set [ find default=yes ] directory=/pub
/snmp set enabled=yes trap-version=2
/system clock set time-zone-name=America/New_York
/system identity set name=212hAP-Ax3
/system logging add disabled=yes topics=wireless
/system logging add action=logserver prefix="XXXXXC MikroTik" topics=hotspot
/system logging add action=logserver prefix="XXXXXC MikroTik" topics=!debug,!packet,!snmp
/system logging add topics=account
/system logging add action=remote prefix="192.168.2.5 " topics=info
/system logging add disabled=yes topics=dhcp
/system logging add action=Graylog topics=debug,packet,wireless,dns,netwatch,dhcp
/system note set show-at-login=no
/system ntp client set enabled=yes
/system ntp client servers add address=192.168.2.2
/system ntp client servers add address=3.pool.ntp.org
/system ntp client servers add address=0.north-america.pool.ntp.org
/tool graphing resource add
/tool mac-server set allowed-interface-list=TRUSTED
/tool mac-server mac-winbox set allowed-interface-list=TRUSTED
/tool netwatch add disabled=no down-script=Netwatch host=1.1.1.1 http-codes="" interval=1m name=Netwatch-1.1.1.1 test-script="" type=simple up-script=Netwatch
/tool romon set enabled=yes
/tool sniffer set file-limit=10000KiB filter-dst-port=syslog filter-interface=all memory-limit=1000KiB
/user group add name=HA policy=reboot,read,write,policy,test,api,!local,!telnet,!ssh,!ftp,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api
(I’m not really in Russia.)
