ROMON fails with frame-types=admit-only-vlan-tagged
I have an RB5009 (ether7) connected to a CRS326 (ether1) with vlan-id=32 setup.
I think the VLAN is working nicely regardless of the frame=type setting for ether 7. But, when I change ether7 from frame=type=admit-all to frame-type=admit-only-vlan-tagged I lose the ability to connect to the CRS via ROMON from the 5009.
CRS326 config:
# 2025-04-10 11:20:26 by RouterOS 7.18.2
# software id = 4RSG-G05N
# model = CRS326-24G-2S+
# serial number = HGC09QKCXFY
add admin-mac=D4:01:C3:83:B5:2F auto-mac=no comment=defconf frame-types=\
    admit-only-vlan-tagged name=bridge vlan-filtering=yes
/interface vlan
add comment=vlan32 interface=bridge name=vlan32 vlan-id=32
add name=LAN
add name=TRUSTED
add comment=OffiBridge name=OffBridge ranges=192.168.55.100-192.168.55.200
/ip smb users
/port
set 0 name=serial0
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
    interface=ether1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22
add bridge=bridge comment=defconf interface=ether23
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
set udp-timeout=10s
set discover-interface-list=all
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1,sfp-sfpplus1 vlan-ids=32
add interface=bridge list=LAN
add interface=vlan32 list=TRUSTED
add interface=bridge list=TRUSTED
/interface ovpn-server server
add mac-address=FE:31:7F:F7:44:46 name=ovpn-server1
add address=192.168.2.7/24 comment=defconf interface=bridge network=\
    192.168.2.0
add address=10.21.32.2/24 interface=vlan32 network=10.21.32.0
add address=192.168.55.1 comment=OffBridge interface=ether24 network=\
    192.168.55.1
add address-pool=OffBridge comment=OffBridge interface=ether24 name=Offbridge
set servers=1.1.1.1,10.21.32.1
/ip hotspot profile
/ip ipsec profile
add disabled=no dst-address=0.0.0.0/0 gateway=10.21.32.1 routing-table=main \
    suppress-hw-offload=no
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/system clock
set time-zone-name=America/New_York
/system identity
set name=CRS326
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool romon
set enabled=yes
/tool sniffer
set filter-interface=vlan32 filter-ip-protocol=icmp
This is the RBN5009 config:
# 2025-04-10 11:20:57 by RouterOS 7.18.2
# software id = 7RPI-TTI6
# model = RB5009UG+S+
# serial number = HJ30
add admin-mac=F4:1E:57:C3:6E:8A auto-mac=no comment=defconf frame-types=\
    admit-only-vlan-tagged name=bridge port-cost-mode=short vlan-filtering=\
    yes
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=\
    "Server1 -- Blue Iris vlan62 access port"
set [ find default-name=ether3 ] comment=\
    "Server2 -- Proxmox/HA vlan62 access port"
set [ find default-name=ether4 ] comment=\
    "hAPax3-downstairs trunk vlans 2, 12, 32, 42"
set [ find default-name=ether5 ] comment=\
    "hAPax3-upstairs trunk vlans 2, 12, 32, 42"
set [ find default-name=ether6 ] comment="Joseph PC access port vlan32"
set [ find default-name=ether7 ] comment="MGMT access port vlan32"
set [ find default-name=ether8 ] comment=OffBridge
set [ find default-name=sfp-sfpplus1 ] comment=CSS326
/interface wireguard
add comment=Wireguard disabled=yes listen-port=53212 mtu=1420 name=wireguard1
/interface vlan
add comment="TV VLAN42" interface=bridge name=vlan-TV vlan-id=42
add comment="Guest WiFi VLAN2" interface=bridge name=vlan-guest vlan-id=2
add comment="IoT  VLAN12" interface=bridge name=vlan-iot vlan-id=12
add comment="Management VLAN32" interface=bridge name=vlan-mgmt vlan-id=32
add comment="MOCA VLAN52" interface=bridge name=vlan-moca vlan-id=52
add interface=bridge name=vlan-printers vlan-id=82
add comment="Servers VLAN62" interface=bridge name=vlan-server vlan-id=62
add comment="VONAGE VLAN72" interface=bridge name=vlan-vonage vlan-id=72
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=TRUSTED
add name=Iot-Cameras
add comment=offbridge-dhcp-server name=offbridge-dhcp-server ranges=\
    192.168.55.2-192.168.55.200
add name=guest-pool ranges=10.21.2.100-10.21.2.252
add name=iot-pool ranges=10.21.12.100-10.21.12.252
add name=cameras-pool ranges=10.21.22.100-10.21.22.252
add name=mgmt-pool ranges=10.21.32.100-10.21.32.252
add name=TV-pool ranges=10.21.42.100-10.21.42.252
add name=MOCA-pool ranges=10.21.52.100-10.21.52.252
add name=servers-pool ranges=10.21.62.100-10.21.62.252
add name=vonage-pool ranges=10.21.72.100-10.21.72.252
add address-pool=guest-pool interface=vlan-guest name=dhcp-guest
add address-pool=iot-pool interface=vlan-iot name=dhcp-iot
add address-pool=mgmt-pool interface=vlan-mgmt name=dhcp-mgmt
add address-pool=offbridge-dhcp-server comment=offbridge-dhcp-server \
    interface=ether8 name=offbridge-dhcp-server
add address-pool=MOCA-pool interface=vlan-moca name=dhcp-moca
add address-pool=servers-pool interface=vlan-server name=dhcp-servers
add address-pool=TV-pool interface=vlan-TV name=dhcp-TV
add address-pool=vonage-pool interface=vlan-vonage name=dhcp-vonage
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment="hAPax3-upstairs trunk vlan1" interface=ether5
add bridge=bridge comment="JRS PC; assign vlan32; access port" frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether6 pvid=32
add bridge=bridge comment=\
    "MGMT; assign vlan32; access port -- temp trunk for CRS" interface=ether7
add bridge=bridge comment="CSS326; trunk vlan1" frame-types=\
    admit-only-vlan-tagged interface=sfp-sfpplus1
    "Server1 -- Blue Iris; assign vlan62 tag; access port" frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether2 \
    internal-path-cost=10 path-cost=10 pvid=62
    "Server2 -- Proxmox/HA; assign vlan62 tag; access port" frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether3 \
add bridge=bridge comment="hAPax3-downstairs; trunk vlan1" frame-types=\
    admit-only-vlan-tagged interface=ether4 internal-path-cost=10 path-cost=\
    10
set discover-interface-list=TRUSTED
/ipv6 settings
    "ports bridge,4,5,sfp to carry vlan2 tagged frames out of 5009" tagged=\
    bridge,ether4,ether5,sfp-sfpplus1 vlan-ids=2
    "port bridge,4,5,sfp to carry vlan12 tagged frames out of 5009" tagged=\
    bridge,ether4,ether5,sfp-sfpplus1 vlan-ids=12
add bridge=bridge comment="ports bridge,4,5,sfp to carry vlan32 out of 5009 AN\
    D assign vlan32 to frames arriving on ports 6,7 -- temp moved 7 to tagged \
    from untagged" tagged=bridge,sfp-sfpplus1,ether4,ether5,ether7 untagged=\
    ether6 vlan-ids=32
    "ports bridge,4,5,sfp to carry vlan42 frames out of 5009" tagged=\
    bridge,ether4,ether5,sfp-sfpplus1 vlan-ids=42
add bridge=bridge comment="ports bridge,sfp to carry vlan52 out of 5009" \
    tagged=bridge,sfp-sfpplus1 vlan-ids=52
add bridge=bridge comment="ports bridge,sfp to carry vlan62 frames out of 5009\
    \_AND assign vlan62 to frames arriving ports 2,3" tagged=\
    bridge,sfp-sfpplus1 untagged=ether2,ether3 vlan-ids=62
    "ports bridge,sfp to carry vlan72 frames out of 5009" tagged=\
    bridge,sfp-sfpplus1 vlan-ids=72
    "ports bridge,sfp to carry vlan 82 frames out of 5009" tagged=\
    bridge,sfp-sfpplus1 vlan-ids=82
add interface=wireguard1 list=TRUSTED
add interface=ether8 list=TRUSTED
add interface=wireguard1 list=LAN
add comment="LAN OffBridge" interface=ether5 list=LAN
add comment="TRUSTED OffBridge" interface=ether5 list=TRUSTED
add comment="LAN VLAN2" interface=vlan-guest list=LAN
add comment="LAN VLAN22" interface=*D list=LAN
add comment="LAN VLAN12" interface=vlan-iot list=LAN
add comment="LAN VLAN32" interface=vlan-mgmt list=LAN
add comment="TRUSTED VLAN32" interface=vlan-mgmt list=TRUSTED
add interface=vlan-iot list=Iot-Cameras
add interface=*D list=Iot-Cameras
add comment="TEMP " interface=ether1 list=TRUSTED
add comment="LAN VLAN62" interface=vlan-server list=LAN
add comment="LAN VLAN52" interface=vlan-moca list=LAN
add comment="LAN VLAN42" interface=vlan-TV list=LAN
add interface=ether7 list=TRUSTED
add mac-address=FE:4D:49:0E:82:FA name=ovpn-server1
add address=192.168.55.1/24 interface=ether8 network=192.168.55.0
add address=10.10.100.212/24 interface=wireguard1 network=10.10.100.0
add address=10.21.2.1/24 interface=vlan-guest network=10.21.2.0
add address=10.21.12.1/24 interface=vlan-iot network=10.21.12.0
add address=10.21.32.1/24 interface=vlan-mgmt network=10.21.32.0
add address=10.21.42.1/24 interface=vlan-TV network=10.21.42.0
add address=10.21.52.1/24 interface=vlan-moca network=10.21.52.0
add address=10.21.62.1/24 interface=vlan-server network=10.21.62.0
add address=10.21.72.1/24 interface=vlan-vonage network=10.21.72.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1d
/ip dhcp-client
add address-pool=cameras-pool interface=*D name=dhcp-cameras
/ip dhcp-server alert
add alert-timeout=1d disabled=no interface=bridge
add address=10.21.2.0/24 dns-server=10.21.2.1 gateway=10.21.2.1
add address=10.21.12.0/24 dns-server=10.21.12.1 gateway=10.21.12.1
add address=10.21.22.0/24 dns-server=10.21.22.1 gateway=10.21.22.1
add address=10.21.32.0/24 dns-server=1.1.1.1 gateway=10.21.32.1
add address=10.21.42.0/24 dns-server=10.21.42.1 gateway=10.21.42.1
add address=10.21.52.0/24 dns-server=10.21.52.1 gateway=10.21.52.1
add address=10.21.62.0/24 dns-server=10.21.62.1 gateway=10.21.62.1
add address=10.21.72.0/24 dns-server=10.21.72.1 gateway=10.21.72.1
add address=192.168.55.0/24 dns-server=1.1.1.1 gateway=192.168.55.1 netmask=\
    24
set allow-remote-requests=yes cache-size=10000KiB servers=1.1.1.1,9.9.9.9
/ip dns static
add address=10.21.32.1 name=212-rb5009-new.212.internal type=A
add address=10.21.32.1 name=RB5009-new.212.internal ttl=9w6d10h40m type=A
add address=10.21.32.1 name=212.10.10.100.212.internal ttl=9w6d10h40m type=A
add address=10.21.32.22 name=JRS-PC.212.internal type=A
add address=192.168.2.2 comment=212router.internal name=212router.internal \
    type=A
add address=10.21.32.2 comment=212router.internal name=212router.internal \
    type=A
add address=10.10.100.80 comment=729router.internal name=729router.internal \
    type=A
/ip firewall address-list
add address=XXXXX.dyndns.org list=dynamic-WANIP
add address=192.168.0.103 comment="Home Assistant" list=\
    ALLOWED-REMOTE-SERVERS
add address=192.168.55.0/24 list=admin
add address=10.0.0.0/8 list=admin
add address=192.168.2.168 comment="Blue Iris 2" list=ALLOWED-REMOTE-SERVERS
add address=192.168.0.101 comment="Blue Iris" list=ALLOWED-REMOTE-SERVERS
    established,related,untracked
    invalid
add action=accept chain=input comment="Allow INPUT users to services" \
    dst-port=53 in-interface-list=LAN log-prefix=users-to-services protocol=\
    udp
    dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input comment="Allow INPUT from TRUSTED" \
    in-interface-list=TRUSTED
add action=accept chain=input comment="Allow INPUT WG Handshake" dst-port=\
    51880 log-prefix=Allow-WG-Handshake protocol=udp
add action=accept chain=input comment="NTP to Devices" in-interface=vlan-mgmt \
    protocol=udp src-port=123
add action=drop chain=input comment="Drop all INPUT" log-prefix=DROP-ALL
add action=fasttrack-connection chain=forward comment=\
    "defconf: fasttrack established related" connection-state=\
    established,related hw-offload=yes
    connection-state=invalid
add action=accept chain=forward comment="Allow FORWARD LAN to WAN" \
    in-interface-list=LAN log-prefix=Allow-LAN-WAN out-interface-list=WAN
add action=accept chain=forward comment="Allow FORWARD TRUSTED" \
    in-interface-list=TRUSTED log-prefix=Allow-TRUSTED out-interface-list=LAN
    "Allow FORWARD Admin & remote wg admin to wireguard" in-interface-list=\
    TRUSTED out-interface=wireguard1 src-address-list=admin
    "Allow FORWARD IOT-CAMERAS iface to ALLOWED-REMOTE-SERVER" \
    dst-address-list=ALLOWED-REMOTE-SERVERS in-interface-list=Iot-Cameras \
add action=accept chain=forward comment="Allow WG relay" in-interface=\
    wireguard1 out-interface=wireguard1
add action=drop chain=forward comment="Drop all FORWARD" log-prefix=DROP-ALL
add action=masquerade chain=srcnat out-interface=wireguard1
add comment=355 disabled=no distance=1 dst-address=192.168.0.0/24 gateway=\
    wireguard1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add comment=255 disabled=no distance=1 dst-address=192.168.1.0/24 gateway=\
    target-scope=10
add comment=355-Cameras disabled=no distance=1 dst-address=192.168.5.0/24 \
    gateway=wireguard1 pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
add comment=629 disabled=no distance=1 dst-address=192.168.20.0/24 gateway=\
    target-scope=10
add comment=76 disabled=no distance=1 dst-address=192.168.30.0/24 gateway=\
    target-scope=10
add comment=371 disabled=no distance=1 dst-address=192.168.40.0/24 gateway=\
    target-scope=10
add comment=125 disabled=no distance=1 dst-address=192.168.70.0/24 gateway=\
    target-scope=10
add disabled=no distance=1 dst-address=192.168.4.0/24 gateway=10.10.100.80 \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=10.0.0.0/8 gateway=wireguard1 \
/system clock
/system identity
set name=212-RB5009-New
/system note
/system ntp client
set enabled=yes
/system ntp client servers
add address=216.239.35.4
add address=104.16.132.229
/system script
add dont-require-permissions=yes name=export-download owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
    \n\
    \n/system\
    \n:local cdate [clock get date] \
    \n:local yyyy  [:pick \$cdate 0  4]\
    \n:local MM    [:pick \$cdate 5  7]\
    \n:local dd    [:pick \$cdate 8 10]\
    \n:local identitydate \"\$[identity get name]_\$yyyy-\$MM-\$dd\"\
    \n/export show-sensitive file=\"\$identitydate\"\
    \n\
    \n/tool fetch upload=yes mode=ftp ascii=no src-path=\"/\$[\$identitydate].\
    rsc\" dst-path=\"/mikrotik-backups/\$[\$identitydate].rsc\" address=192.16\
    8.2.22 port=21 user=mikrotik password=XXXXX\
    \n\
    \n/file remove \"\$[\$identitydate].rsc\"\
    \n\
    \n:log info (\"Uploaded rsc backup to 192.168.2.22 as \".\$identitydate)"
add dont-require-permissions=yes name=Netwatch owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
    \n# Netwatch script\
    \n#\
    \n# Used as both up and down script\
    \n# Created Jotne 2021 v1.5\
    \n#\
    \n####################################\
    \n:local Host \$host\
    \n/tool netwatch\
    \n:local Status [get [find where host=\"\$Host\"] status]\
    \n:local Comment [get [find where host=\"\$Host\"] comment]\
    \n:local Interval [get [find where host=\"\$Host\"] interval]\
    \n:local Since [get [find where host=\"\$Host\"] since]\
    \n:log info \"script=netwatch watch_host=\$Host comment=\\\"\$Comment\\\" \
    status=\$Status interval=\$Interval since=\\\"\$Since\\\"\"\
    \n\
    \n:local thisBox [/system identity get name];\
    \n\
    \n:tool e-mail send to=jXXXXX@domain.com subject=\"\$thisBox \$Status\
    \_to \$Host\" body=( [ :system clock get date ] . \" \" . [ :system clock \
    get time ] . \"\$thisBox \$Status to \$Host\" )\
    \n"
/tool e-mail
set from=jXXXXX@domain.com port=587 server=smtp.gmail.com tls=starttls \
    user=jXXXXX@domain.com
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/tool netwatch
add comment=Netwatch-8.8.4.4 disabled=no down-script=Netwatch host=8.8.4.4 \
    http-codes="" interval=5m name=Netwatch-8.8.4.4 test-script="" type=\
    simple up-script=Netwatch
add disabled=no down-script=Netwatch host=192.168.0.11 http-codes="" \
    interval=1m name=Netwatch-192.168.0.11 test-script="" type=simple \
    up-script=Netwatch
/tool romon
set enabled=yes
SWITCH
Why are you treating the switch like a router?
The only address on the switch is the one given to the switch over the management vlan32 ???
Bridge is not involved… reminder to look at switch example: http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
There is only need of ONE interface list entry, aka TRUSTED, which the bridge has nothing to do with…
add interface=ether24 list=TRUSTED
Removing:
    192.168.2.0
And making the only interface list “TRUSTED” with vlan32 and ether24 did not fix the problem.
Edit: I’d originally thought it was RoMON getting dropped, @sindy confirms the bridge’s frame-types= are passed.
See @sindy’s post : https://forum.mikrotik.com/viewtopic.php?p=1137826#p1137981
Wow, great understanding and explanation.
So what is the recommended configuration? To use admit-only-vlan-tagged or not? If yes, how would I access the CRS with Winbox?
ROUTER
You have a disconnect and duplication when I noted on your trusted listed you had three ports ( vice just one trusted offbridge port ) identified.
The fallout of that is
  1. a. in ethernet interface settings you identify ether5 as the hapax upstairs, and on /interface bridge ports ( athough missing frame types of tagged only )
    b. In Interface list you have → both wrong and should be removed!
    add comment=“LAN OffBridge” interface=ether5 list=LAN
    add comment=“TRUSTED OffBridge” interface**=ether5** list=TRUSTED
  2. It would appear that ether8 is actually your Offbridge port is 8. ( as per ethernet interface identification and member of Trusted list already )
    NEED to then add:
    add interface=ether8 list=LAN
  3. REMOVE ether7 from the interface list Trusted.
    Why do you have it here? The access port is for vlan32 (management vlan) and thus the PC already has access to the LAN/TRUSTED via vlan32 interface entries???
  4. You have other interface errors indicated by the *D entries on the config…
    add comment=“LAN VLAN22” interface=*D list=LAN
  5. Not sure of the purpose here… but feels like a security risk!.
  6. This has no place on interface list. Should be removed.
  7. Besides the normal 8 dhcp server config entries you have an additional entry further below.
    add address-pool=cameras-pool interface**=D* name=dhcp-cameras
  8. Assigning ether7, tagged here
    add bridge=bridge comment=“ports bridge,4,5,sfp to carry vlan32 out of 5009 AN
    D assign vlan32 to frames arriving on ports 6,7 – temp moved 7 to tagged
    from untagged” tagged=bridge,sfp-sfpplus1,ether4,ether5**,ether7** untagged=
    ether6 vlan-ids=32
Conflicts with ethernet interface identification: -->set [ find default-name=ether6 ] comment=“Joseph PC access port vlan32”
So what is now on ether7??
What are you using ROMON for,that is not available through neighbours discovery?
I need Romon to access the CRS.
Do your corrections allow me to do this?
What is the conflict?
I am having difficulty identifying the conflict.
ether7 is the CRS.
I access all my downstream devices, ax3 ap, hex switch, etc via neighbours discovery not ROMON (via winbox)
(deleted)
The config paints a conflicted story?
Hard to find ether7 tagged for any vlans going to CRS326 ???
“ports bridge,4,5,sfp to carry vlan2 tagged frames out of 5009” tagged=
“port bridge,4,5,sfp to carry vlan12 tagged frames out of 5009” tagged=
“ports bridge,4,5,sfp to carry vlan42 frames out of 5009” tagged=
add bridge=bridge comment=“ports bridge,sfp to carry vlan52 out of 5009”
add bridge=bridge comment=“ports bridge,sfp to carry vlan62 frames out of 5009
_AND assign vlan62 to frames arriving ports 2,3” tagged=
“ports bridge,sfp to carry vlan72 frames out of 5009” tagged=
“ports bridge,sfp to carry vlan 82 frames out of 5009” tagged=
Who told you this… ???
its clear that even though ROMON should not be affected by vlan tag settings on the bridge itself, they are, so avoid its use is my advice.
Okay, I understand.
I am waiting for delivery of an SFP cable. until then I wanted to use ether 7 temporarily. So, I had it all set up to use SFP between 5009 and CRS.
I do have vlan32 carried over ether7 – just to get a basic level of functioning.
So this test bed (5009-lab and CRS) is set up as such:
5009-lab is connected to an operational 5009 (aka 5009-operational) which is my home network (flat, single /24 LAN).
Hence, the PCs I use to run Winbox can see the main network’s 5009-lab, but cannot see the CRS connected it to.
With admit-vlan-tagged-only NOT set, I can romon into the 5009-lab and the 5009-lab will let me connect to the CRS.
If admit-vlan-tagged-only IS set, ROMON does not work.
My only way in to the CRS is to MAC-TELNET from 5009-lan to the CRS. This leaves me with only the CLI, which I am learning, but still need winbox somewhat.
Got it – RoMON is not carried across vlan-tagged frames because RoMON frames are neither IP nor IP+VLAN type frames. (Is this an accurate way of describing it?).
According to CGX, there were no shortcomings to using bridge itself vlan tagged, so I hesitate to completely swallow the information provided by AMMO and maybe in-between is a more accurate answer???
It would appear to me that any data from a PC trying to talk ROMON that is assumed to be on the management vlan would get tagged on entry (regardless if it was ethernet with embedded romon information). So logically it should work. From the Documentation, ROMON is not a vlan entity and thus should not even be seen. I gather then you have a physical cable attached between master5009 and Lab5009 then?? Where is that indicated on the LAB 5009 config??
If that traffic is coming over a trunk port, router to router, on vlan32, my guess is that it will work.
ether1 (WAN)
Only stating there was a second 5009 at play at such a late stage, and that the Romon issue stemmed from the first one to the Switch was a criminal omission. Consider yourself flogged :wink:
Your punishment is having to eat the entire plate of smoked meat served at Katz’s.
LOL!!!
Just trying to keep you all on your game.
But, speaking of high crimes, pastrami is cured first, then smoked for flavor! Such an omission!
