Romon - How use more secrets?
I can set more secrets in winbox tools → romon. But I see in romon neighbours only first field secrets.
I have network with ccr1016 with pppoe server. Vlan with 12 switch crs125 without romon secrets. PPPoE clinets (149x) RB951 with various romon secrets by name of apartmes block. (s1byty, s2byty, s3byty, s4byty, s5byty).
I set on ccr1016
/tools romon
set enabled=yes secrets=s1byty,s2byty,s3byty,s4byty,s5byty
on rb951 apartment one:
/tools romon
on rb951 apartment two:
/tools romon
set enabled=yes secrets=s2byty
When I conect to ccr1016 to romon I see romon neighbours only s1byty. I´d like see all. It’s possible?
Ros 6.41
Thank you
I found only the first will work work also.
However you can use the ports option and add another secret to a port, overriding the default, you can also forbid this way also.
But the whole list will also pass over including those from the other secrets, it won’t restrict one secret network from another.
