Romon Multiple Secrets
From both the wiki.mikroitk.com and help.mikrotik.com:
https://wiki.mikrotik.com/wiki/Manual:Tools/RoMON#Secrets
https://help.mikrotik.com/docs/display/ROS/RoMON#RoMON-Secrets
  • configure each router one by one with secrets=“”,“mysecret”
yet when you do that…
RoS7.1.1
[admin@Classroom v7 ] /tool/romon> set secrets=“”,“mysecret”
expected end of command (line 1 column 15)
RoS 6.59
[admin@Class Router 1] /tool romon> set secrets=“”,“mysecret”
But when you add a couple of secrets via the GUI and export using show-sensitive:
/tool/romon> exp show-sen
/tool romon
set enabled=yes secrets=“mysecret,""”
/tool romon set secret=test1,test2 works
/tool romon set secret=test1,“” does not work, yet /tool romon set secret=“"".test1” works.
It seems the Wiki/Help syntax is incorrect ? Can anyone confirm this please ?
