Where can be downloaded utility RoMON (http://wiki.mikrotik.com/wiki/Manual:RoMON) presented on MUM Prague 2015? In last version beta package is not included.
romon is a feature that will be included in RouterOS 6.28 or 6.29
It is not a tool, but a command menu in RouterOS
Integrate it to winbox user interface and do not leave it to cli only.
currently romon supports SSH only, so in which way do you mean “integrate into gui”?
eventually romon will have more features, yes.
I am just asking to have it available thru the windows interface and maybe it should be integrated to neighbours window, maybe with some mark that the record is obtained via romon and not via standard discovery feature. Everywhere the ping or Mac ping and the telnet is offered, the romon ping, ssh or maybe future romon telnet should be enabled also. And finally there should be winbox connection able to run over it! Winbox should be able to discover devices using romon too.
