ROS 3.0rc9 SNMP Bugs
Hi Guys,
Bug report:
Only the 1st SNMP community string added to the SNMP server works
To recreate:
  1. Enable SNMP Server in SNMP Settings
  2. Add community string of choice
– SNMP queries work at this point
  1. Add additional string of choice
    – SNMP query against (2) still works but against (3) it fails
  2. Deleting (2) does not enable (3)
Tested on 2 RB333 units running rc9
I never tried to have more than one string in snmp, what would be the reason for this? Either your snmp tool has access to the MT OIDs or it doesn’t right?
Scott
allowing more then one device access to snmp, without allowing everything access (since we STILL can’t allow more then one address or subnet access to a particular community string)
So if I have a monitoring and reporting device on say 200.200.200.200 and it monitors the “mypublic” community string on the MT router then only the 200.200.200.200 device can access the router with snmp? My other monitoring tool on 200.200.200.199 can’t query the MT router for OIDs?
I haven’t monitored any MT gear yet but I’m getting ready to…
Thanks,
Scott
Here, after I update to v5.0rc9 SNMP stopped working. If I delete community settings, disable and restart the RB, SNMP
settings are correct. If I turn on SNMP, the system automatically creates a second entry and simply does not work. Look at the picture.
I upgraded 4 RBs 433AH to version 5.0rc9. Two SNMP work perfectly. In RBs, where works SNMP, wireless cards are XR5 and configured for Xr5+Turbo mode. In RBs, where not works SNMP, wireless cards are R52HN NV2 and configured NV2 Nstreme..
