ROS 3.12 - SIP Helper
Good day
Does anyone know if the SIP Helper in V3.12 has been “fixed”..??
Tanker
I didn’t know it was broken.
I’m using sip devices behind ROS 3.11 with NAT and it seems to work ok.
The connection manager shows the udp connection as “SIP”, so I assume the SIP helper is running.
What are the symptoms when it doesn’t work? I’d like to understand this better since we’re in the process of
deploying more VOIP on our wireless network.
*** BUMP ***
Anyone???
