sorry for that kind of topic ;> but i cant download whole package and not only me 430 leech 0 seeds
you sure? try again maybe, cause I can download fine
everyone else - please seed
Same here, I see bunch of 99,8% peers, and 0 seeders. I used HTTP links for specific architectures to get v3.14.
normis: :> sure im sure
0 seeds, 99.8 percent complete
regards
99,8% here and no seeds also ;-(
same here :< 99,8% and 0 seeds…
still cannot finish downloading… MT please do something…
working on it, should work in 30-60 minutes ![]()
still 0 seeds…
don’t push it ![]()
We made a new torrent, please re-download the ALL file
utorrent says that torrent not registered with this tracker
still no seeds
after deleting old one and download a new one torrent file from mikrotik.com
*UPDATE
new torrent is downloading to a routeros-ALL-3.14_
folder
but 0 seeds 3 leechs
After re-downloading ALL file my torrent client is giving me this.
rejected by tracker - Torrent not registered with this tracker.
-Louis
same here…
do a save as a torrent file and save it to another location on your disk, delete old torrent in your software (i.e. utorrent) and load new one from disk
still 0 seeds
still the same error ![]()
make sure you don’t get the same torrent file, we noticed that it likes to be stuck in some proxy caches
normis: i think the best way to avoid this problem is changing the name of the file (i.e adding the _ to the torrent file name)
still no seeds ![]()
Im not using any proxy. I downloaded “new” torrent, changed name of this torrent, tried to download from different network, and problem is still the same…
try to ctrl + f5 on download page.
check if your torrent label in utorrent have a _ on the end
ze tak powiem po polskiemu
ma dzialac tylko ze nie ma seeda ![]()
