Have setup-ed web proxy with nat redirect rules from the manual, and the proxy rules are working fine. Cache is setu about 1 gb. No parent proxy. But I have installed dyndns updater tool on windows box and when I disable nat rule for the proxy I can update the with dyndns but when the rule is enabled I cannot. The dyndns script is not working either.
Any help would be appreciated.
DannyZ
January 10, 2010, 7:55pm
2
And how about Ros upgrade to at least 3.30?
Will do!
Now the script is working, but the dyndns updater tool is still now working. Maybe I need a rule for the tool ?
DannyZ
January 10, 2010, 9:46pm
4
drop here your firewall rules
Here are the rules
0 chain=srcnat action=masquerade src-address=192.168.50.0/24
out-interface=ADSL
1 chain=dstnat action=redirect to-ports=3128 protocol=tcp dst-port=80
The dyndns script on the ros is working but the dyndns update tool behind the proxy isn’t.
I have another script for a resolving a dyndns name for another MT that is runnign pptp server and I have setup-ed a pptp client on my ros 3.22.
:global pptp-interface “pptp-out1”
:global pptp-connect-host “someone.dyndns.org ”
:global pptp-host-ip [:resolve $pptp-connect-host]
:global pptp-connect-to [/interface pptp-client get $pptp-interface connect-to]
:if ($pptp-host-ip != $pptp-connect-to) do={
:log info “Updating VPN Server IP address”
/interface pptp-client set $pptp-interface connect-to=$pptp-host-ip}
I know this script is working on v2.9 but it is not working on this version , cannot find the problem.
Any advice appreciated.
