When I use in-bridge-port or out-bridge-port in filter rule, this rule sometimes work, sometimes not without change.
After reboot ROS, rules work fine, but after time doen’t work again!
This rule still not work:
chain=forward action=accept connection-state=new in-interface=W1 out-bridge-port=DMZ
Interface W1 is eternet to ISP, and DMZ id any port from Bridge !!!
I have problem with bridge filtering. I try this on three ROS and filtering doesn’t work correctly.
I have 4 and more ethernet interfaces in bridge. When I have 2 interfaces, filtering is OK.
I try simple filters rules with log traffic and more traffic doesn’t catch on filter. It’s bug!
We actually just had a 564, do some weird stuff but we don’t have any firewall rules or the Firewall turned on.
The issue is that one some websites, it hangs. Right in the middle of the page it stops and just says waiting for site. Reboot the unit, it works fine for a while, (have not been able to put a time on it) and then after a while, it starts to hang on cirtian sites.
Once we get the 2.9 running and let it run for while, we will see if the problem resurfaces.
All 9 Ethernets are bridged between two bridges. Soo.. If it don’t resurface after tomorrow, we may put 3.3 back on it, and wait till it happens again and generate a supout. Make sure if you have this issue to send that supout.rif to support@mikrotik.com
