Hi fewi,
(sorry some of the contents are edited for confidentiality)
/interface export
jan/03/1970 06:34:43 by RouterOS 4.10
software id = ELRV-XXXX
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
comment=“” disabled=no forward-delay=15s l2mtu=2290 max-message-age=20s
mtu=1500 name=bridge1 priority=0x8000 protocol-mode=none
transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes comment=“” disabled=no full-duplex=yes
l2mtu=1526 mac-address=00:0C:42:13:E5:56 mtu=1500 name=ether1 speed=
100Mbps
/interface vlan
add arp=enabled comment=“” disabled=no interface=bridge1 l2mtu=2286 mtu=1500
name=vlan-mgmt use-service-tag=no vlan-id=220
name=vlan-data use-service-tag=no vlan-id=241
/interface pppoe-client
add ac-name=“” add-default-route=yes allow=pap,chap,mschap1,mschap2 comment=
“” dial-on-demand=no disabled=no interface=vlan-data max-mru=1480 max-mtu=
1480 mrru=disabled name=pppoe-out1 password=xxxxx profile=default
service-name=“” use-peer-dns=yes user=xxxxx
set default authentication-types=“” eap-methods=passthrough group-ciphers=“”
group-key-update=5m interim-update=0s management-protection=disabled
management-protection-key=“” mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“”
static-sta-private-algo=none static-sta-private-key=“”
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“”
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area=“” arp=enabled band=5ghz
basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment=“”
compression=no country=no_country_set default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=
yes dfs-mode=none disable-running-check=no disabled=no
disconnect-timeout=3s frame-lifetime=0 frequency=5100 frequency-mode=
superchannel frequency-offset=0 hide-ssid=no hw-fragmentation-threshold=
disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=4
l2mtu=2290 mac-address=00:80:48:7F:F2:92 max-station-count=2007 mode=
station-wds mtu=1500 name=wlan1 noise-floor-threshold=default
on-fail-retry-time=100ms periodic-calibration=default
periodic-calibration-interval=60 preamble-mode=both
proprietary-extensions=post-2.9.25 radio-name=CPE100 rate-set=
configured scan-list=5100-5500 security-profile=default ssid=LOG1
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=
6Mbps,9Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=
default update-stats-interval=disabled wds-cost-range=50-150
wds-default-bridge=bridge1 wds-default-cost=100 wds-ignore-ssid=no
wds-mode=dynamic wmm-support=disabled
/interface wireless nstreme
set wlan1 comment=“” disable-csma=no enable-nstreme=yes enable-polling=yes
framer-limit=3200 framer-policy=none
/interface wireless manual-tx-power-table
set wlan1 comment=“” manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,
6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps
:17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:
0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0”
add bridge=bridge1 comment=“” disabled=no edge=auto external-fdb=auto
horizon=none interface=wlan1 path-cost=10 point-to-point=auto priority=
0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:FD:89:4C:C3:9F
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/interface print
NAME TYPE MTU L2MTU
0 R ether1 ether 1500 1526
1 R wlan1 wlan 1500 2290
2 R bridge1 bridge 1500 2290
3 R vlan-data vlan 1500 2286
4 R vlan-mgmt vlan 1500 2286
5 R pppoe-out1 pppoe-out 1480
/ip add export
jan/03/1970 06:46:44 by RouterOS 4.10
add address=192.168.1.1/24 broadcast=192.168.1.255 comment=“” disabled=no interface=ether1 network=192.168.1.0
add address=10.10.10.29/24 broadcast=10.10.10.255 comment=“” disabled=no interface=vlan-mgmt network=10.10.10.0
/ip rou pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 202.xxx.xxx.xxx 1
1 S 10.0.0.0/8 10.10.10.1 1
2 ADC 192.168.1.0/24 192.168.1.1 ether1 0
3 ADC 202.xxx.xxx.xxx/32 202.xxx.xxx.xxx pppoe-out1 0
