ROS 4.5 XR5 10Mhz no scan results
When I switch the the wireless “band” to 5GHz-10MHz with ROS 4.5 and an XR5 and I try to scan for APs out there I get “ERROR: scan not running Or click here to see them all.”.
This is strange because I know there are 10MHz 5 Ghz APs that I should pick-up (they show up with StarO/S).
Is this an issue with ROS 4.5 / XR5 or is there some other ROS setting to get 10Mhz 5Ghz channels working?
thanks,
Derek
Hi dconnrt;
Did you solved your above problem? if yes let me know fixing way please.
Thanks in advance
