ROS 5.2 Interfaces dissapeared!
Few times happened, and here comes the problem again. Suddenly, all the interfaces dissaper, all IP addresses are listed, but no interface assigned to it. All IP’s (both IPv4 and IPv6) are on UNKNOWN. When trying to list the interfaces, got ERROR:timeout. The same happens on Wireless, Bridge, PPP, Mesh…
I can list files, look at log, BGP works fine. All PPPoE and PPTP customers are unable to use the internet. The dynamic queues gave lost their assignment to the interface.
In the same time, all computers and servers with static IP addresses works OK.
I made supout.rif, but due to large size, I can’t attach it here.
Here is a link to download it:
http://red.smartdoit.com/BJB/razno/supout.rif
Hope that it will help finding the problem.
Everything comes back to normal after software reboot.
Hardware is HP Proliant x86, two Xeon dual core CPUs.
I had never this problem with earlier Mtik versions. Well, something went wrong :slight_smile:
Does anybody have any clue?? Thank you!
any news?:slight_smile:
yo he visto este problema, pero lo he resuelto cambiando la fuente, no se si ese sera el mismo caso que el tuyo.
I have seen this problem, but I fixed by changing the power source, will be the same case as yours.
Thank you for your submission, but the power supply should not be the reason for this. At least not in my case. Im running the router on HP Proliant Xeon based server. It has dual PSUs after all :slight_smile:
