I upgraded from 2.9.50 to 5.4 on rb532. Parameters of connection(stability, quality, throughoutput) went rapidly down.
Is that normal?
I was running 5.2 for a couple of weeks, then upgraded to 5.4 hoping it would improve 2.4GHz.
I downgraded to 4.17 and it cleared right up.
4.17 seems to be comparable to 3.30 for reliability of 2.4GHz.
4,17 I teste also and is something like 5.4. Much worse than 3.30.
try to reset the wireless card configuration and reconfigure from the start the wireless settings in v5.4
