hi,
since my upgrade of a few RB433AH to ROS 5.4 i can not monitor the voltage anymore with this OID:
.1.3.6.1.4.1.14988.1.1.3.8.0
anybody else having the same issue ?
regards
Jan
hi,
regards
Jan
Yes, we have had to roll back to 5.2 on our monitored sites.. They were supposed to be fixing one thing… Oh well, that’s why they are Mikrotik…
the same problem but strange on 2 rb 433AH - working ok , one 433ah doesn’t work and one 333 the same snmv voltage monitor doesn’t work after upgrade to 5.4 ![]()
hello, have you report problem to mikrotik support also with .rif?
mikrotik support will fast response. ![]()
