Someone had tried to install Ros version 5.5 on rb 112 and 133?
There are problems, or work fine?
Thanks.
Thanks.
Dont expect too much performance, but it works ok. Better than 3.x and 4.x.
NV2/Nstreme needs CPU so better drive them with plain 802.11.
I use 5.5 on 112. You must be very careful to install only the packages that you need and to turn off all services that you don’t use. I think the main limiting factor is the RAM. It seems to start swapping to the flash, causing 100% CPU and lockup in 1-5 minutes.
GL
Installed on 112 and 133c.
After 14 hours all work fine without remove any package…
The throughput seems to be better than “old” 4.xx… more stable.
Very nice web interface!
