ROS 5.X not supported on Hyper-V
Hi all!
I am working with ROS 4.x on a virtual machine on Hyper-V. Everything was working fine until I did an upgrade to version 5.0 or 5.1. The system is starting with no errors, also the network adapters are available but there is no network connection. No ping, no management over Layer 2, nothing.
Do you have any ideas?
Thanks,
Philipp
Same problem here.
On Hyper-V R2 server, legacy network card is seen by RouterOS 5.4
Other routers on the network see the virtual router in their neighbourlist, but all other traffic fails.
RouterOS 4.17 on the same server works fine.
Anyone found a solution?
Stephan
The same problem. Somebody any ideas?
10x
And the same here, any ideas?
same here! :frowning:
anyone have an update on this?
Same here too!
Microtik does not work on Hyper-V?
Any solution yet?
Maybe I missed it..
Almost a year has passed since this topic was created and there is still no solution or response from mikrotik?
I too am trying to get RouterOS on my Hyper-V system and am unable to do so sucessfully.
I guess MikroTik us uniterested in supporting RouterOS running on Hyper-V.
search on global network would show articles like this one:
http://www.networkworld.com/news/2011/071811-microsoft-hyperv-linux.html
where you clearly can see where the problem is.
There are many threads about this, search should
janisk,
I stand corrected.
I did not realize that the problem is a microsoft support of Linux issue rather than a MikroTik support of Hyper-V.
Maybe I should switch to VMWare…
:frowning:
A little OT in this thread, but while ROS does work on VMware, I didn’t see any extra support (e.g. vmxnet3 driver, even though it is available in kernel version used by ROS), last time I checked. Sometimes I wonder how much MikroTik really wants to support virtualized ROS.
we do not support virtualization of RouterOS, but if it is working we will not change anything to stop it. Also, do to fact that RouterOS uses KVM by itself, best results you will have if you use KVM virtual machine to run RouterOS. You just have to slightly change CPU settings to match your CPU from default value.
I just installed the ROS 3.2 on Hyper-v in 2k8R2 and set the physical interface to virtual machine, but the routerOS not identified any ethernet interface, isn’t there any additional driver or something like that for old routerOSes?
no there is not and have not been any support for Hyper-V. Generic parts that are provided by Hyper-V enables to install RouterOS as a guest there, but as far as i know ethernet ports are missing as either there are no kernel modules or ones that are there have been updated by their vendor and driver from original vendor does not match with virtual devices provided by Hyper-V.
Thanks Janisk for light answer
for example similar problem was with VMware and e1000 when intel released refreshed version with some new bells and whistles. Result - virtual card that used that driver stopped working. While hardware cards continued to work as before.
I can’t believe it has been 2 years since the original post on this thread and we still are EXACTLY in the same spot we were when we started.
For God’s sake, we put men on the moon using a computer with less computing power than an RB250G. You would think that SOMEONE by now would be able to figure out how to get the stinking ethernet ports to be recognized by RouterOS when run on Hyper-V!!
But alas, it seems it is not technology that is the boulder in the highway, it is finger-pointing and the blame-game. “It’s MS’s fault”. “No it’s not, it’s Mikrotik’s fault” “No it’s really the Linux community’s fault”… WHO FRIGGING CARES WHO IS AT FAULT.
Just FIX the DAMNED thing already.
MK - Step up to the plate, be like the Apollo 13 astronauts, grab some flipping duct tape, some popsicle sticks and chewing gum and FIX THE ISSUE PLEASE.
I know this thread is old but I had to write a reply to it.
The only reason why the RouterOS stopped working with Hyper-v has to be because Mikrotik does not want it to work!
Vyatta uses the Linux kernel as well and they haven’t removed the hyper-v modules which results on, Vyatta router software working perfectly with the synthetic network adapters and the legacy network adapters in Hyper-V and providing full bandwidth with great performance.
It’s incorrect to blame Microsoft as the support is there. Every other Linux distribution works well in Hyper-V with the integrated support for Hyper-V on the Linux kernel. The modules are built in.
I was with Mikrotik for many years with many routerboards building our bridges, access points and routers. Last year we had to decide: Or drop Hyper-V or drop Mikrotik for our on premises cloud. So, Vyatta was the selected and slowly our Mikrotik hardware will be replaced by Cisco hardware.
I’ve been into an IT managers conference and found more people with the same problems and dropping Mikrotik as well and others turning to other solutions. The fact is: Hyper-V is good! Is free! Works well! We will not move from Hyper-V because of Mikrotik’s position against supporting it. There are other routers that work well virtualised with Hyper-V, that’s it!
this is due to discrepancies between hardware that is virtualized and actual hardware that has this driver written for. Similar to Vmware implementation of e1000 hardware did not follow driver expectancies and was not usable for a while, after vmware updated their “intel hardware” everything started to work again.
And actual hardware support is the priority for RouterOS, so virtualized hardware will not be supported.
and so licenses for virtual instances or ROS will not be purchased… fix the drivers to support hyper-v (hint: they already exist, you just need to include them), and you’ll sell more licenses.
