do not work dhcp client on vlan, works on ethernet. Netcard intel i350t2, on intel CT desktop work. wrote to say that such a support driver. How to fix the problem?
Ticket#2013012866000825
Regards, Alexandr
We are looking for solution for your problem. It is the problem of the specific network interface card driver, it has nothing to do with rc8 version.
sergejs ,
If the problem solved also the micro usb and connect a hard disk of the router?
Is there a shift in a positive way?
Is it just I have a problem?
Not only you.
And there is still that problem on ROS 6.0 rc9
I use RB433UAH plus sereral RB751U/RB751G routers.
Good day, there is a solution? I bought a motherboard, 5.x not fully support it (chipset Q77), and 6.x is not working on vlan dhcp
Whether the solution to my problem?
