ROS 6.04 Time Zone and Winbox
So the last 2011s I ordered showed up with ROS 6.01 on them. After base config i upgraded them to 6.04. I then noticed that I could not set the Time Zone from winbox. I have always used the drop down to see what locations are available. Once I have that info, I would often commit it in “New Terminal.”
But I couldn’t do anything with that parameter outside of terminal. Is that normal with ROS 6?
This issue is known and will be fixed in version 6.5. For now, go back to the same menu again (close and reopen) and it’ll be active.
Thanks pcunite.
Also… I noticed some problems trying to change passwords in winbox. Another known issue?
