ROS 6.19 simple queue 100% cpu
I have ~1500 simple queues(like on photo attached) on my CCR1016, I see that CPU_1 is 100% loaded and speeds are awful.
CCR does not share cpu amont cores when shaping
when this behavior will be fixed and when will shaping load balanced among all cores,
will address-list issue be fixed in 6.20, I don’t see this fix in change-logs
Mikrotik??
where is fix
Is this true? I heard same thing too from some forum, 1 core per port. Means CCR1016-12G won’t user core 13-16?
it is using all cores for some tasks, but for shaping seems it can not load balance
if 1500 queues are on the top level (no parents) queues should be fine, also all ethernets are using all CPU cores, so if you see 100% load on one core it is something else, some other part of configuration. You should ether post whole export or send mail to support.
when disable these queues cpu sits at 10%
