Since 4.x, I have never lost configuration, even through major version upgrades.
Last I heard, exporting configuration with Dude 4.0b3 could crash the system and wipe out the map.
Now that I’m searching for answers, I’m finding this is happening to many people. The only mention of Dude in the 6.20 release notes was the ability to see & remove the Dude package. I realize this was probably an unknown effect at the time of release, but when a new release is causing widespread destruction, shouldn’t MT either a) pull the software; b) release a new version without the problem; or c) contact users to warn them?
As far as I could tell, this was an ordinary release like any other–certainly no risk to a machine running nothing but Dude! Right?
So I upgrade, and now no clients can log in. Then I downgrade, and I’m greeted with a blank map. Just like dozens of others, evidently. There has to be a better policy than caveat emptor when upgrading ROS.
I am running 4b3 dude on Windows and pressing export quite often. No data loose. When I migrated dude from host to host I just imported last backup and it worked as expected.
I believe the problem was with x86 machines running ROS. Do I dare risk crashing my Dude server to see if export works–today? Will the next release irretrievably brick ever mipsbe board?
There has to be -some- level at which we can count on ROS (and the upgrade-downgrade process) to work without causing damage; and when people discover that something does cause damage, to bring it to the attention to the user base immediately and proactively, so that more people don’t keep falling into the same known trap.
If you were following this forum, you could know that in 6.19 it was not possible to uninstall the dude from ros. This is not taking care about dude but just about ros. Nothing more.
Sometimes I follow the forum closely, other times not as much. The bottom line is, there was no reason to expect that upgrading and downgrading ROS this time, unlike all other times, would wipe out the Dude configuration; and when the problem became known, MT didn’t immediately release 6.21 with a fix, or pull 6.20, or mail out updated release notes with a warming, or do any of a dozen other things they could have done to keep more of their user base out of a bind. It isn’t good communication when the only time you hear about problems is from the user forums.
Yes, you are right. Mikrotik just made step forward in the dude devastating. Change logs are still something that mikrotik does very badly. Then user needs to read almost everything on this forum to get clear picture as good as possible.
My config gone too, but with 6.19 - export don`t work as well, but sometimes…
After open Dude in windows machice, do it fast! (Works for me)
Click export button keep your finger on “enter” to immediately save backup
Sometime Dude closing connection, then save window not appear.
