I’m running the ROS 6.32.3 in a CCR1036-12G-4S and it’s working as PPPoE server.
Today I saw a very strange problem: if I disconnect the cable of the client that is connected on this PPPoE server the PPPoE user doesn’t disconnect from the server, the username continues connected on the Active Connections of the PPPoE.
When I plug the cable again the user can’t connect (because it’s connected on the server), I have to delete the username from the Active Connections on winbox to the user reconnect again.
Is this a bug of the 6.32.3 version of ROS?
I’ll upgrade the server but I’ll need to do it tonight because I’ve a lot of users connected on it.
Fabrício
