ROS 6.32.4 better then 6.35 in queuing
I have to mention that routeros 6.23 and routeros 6.32.4 both have better per core queue balancing and performance results than ROS 6.34 or 6.35,
exactly same network loading, same hardware and everything the same leads us to following results for the production router
queuing 38% vs <23%
CPU cores 70-85%(some of them) vs 45-60%( some of cores)
router ccr 1036
780-850mb traffic, 12000 queues
we tested newer ROS versions(post 6.32.4) in another network on another ccr1036 with the same results
I could not make support file, during making it crashed(stopped creating file) and then it was writing that it is busy (error 12)
router was working as before
then I downgraded and was not able to reboot and try making support file again, it was production router, I had to downgrade it immediately
