Hi! I’ve been seeing a lot of IKE & IPsec updates recently in the ROS changelogs, and from what I was seeing, it seems there’s better support now for IPsec w/ XAUTH authentication as a client on the Mikrotik?
I currently have a VPN Client (client to site) connection using IKEC/IKED on Linux, and would rather set it up in my Mikrotik HEX router.
n:version:4
n:network-ike-port:500
n:network-mtu-size:1380
n:client-addr-auto:1
n:network-natt-port:4500
n:network-natt-rate:15
n:network-frag-size:540
n:network-dpd-enable:1
n:client-banner-enable:1
n:network-notify-enable:1
n:client-dns-used:1
n:client-dns-auto:1
n:client-dns-suffix-auto:1
n:client-splitdns-used:1
n:client-splitdns-auto:1
n:client-wins-used:1
n:client-wins-auto:1
n:phase1-dhgroup:5
n:phase1-life-secs:86400
n:phase1-life-kbytes:0
n:vendor-chkpt-enable:0
n:phase2-life-secs:3600
n:phase2-life-kbytes:0
n:policy-nailed:0
n:policy-list-auto:0
s:network-host:111.222.111.222 (redacted)
s:client-auto-mode:pull
s:client-iface:virtual
s:network-natt-mode:enable
s:network-frag-mode:enable
s:auth-method:mutual-psk-xauth
s:ident-client-type:keyid
s:ident-server-type:any
b:auth-mutual-psk:xxxxxxxxxxxxxxxxxxxxxxx(redacted)
s:phase1-exchange:aggressive
s:phase1-cipher:auto
s:phase1-hash:auto
s:phase2-transform:auto
s:phase2-hmac:auto
s:ipcomp-transform:disabled
n:phase2-pfsgroup:5
s:policy-level:auto
s:policy-list-include:10.0.0.0 / 255.0.0.0
What I have set in Winbox:
IP->IPSec, Peers, added a peer:
address: 111.222.111.222
Auth Method: pre shared key xauth
exchange method: aggressive (the Fortigate is set to aggressive as well)
Secret: (same psk as on fortigate)
Xauth: myuser
Xauth password: mypassword
… and I’m stuck at this point. Not sure what I should set as IPsec policy since the remote Fortigate is supposed to randomly assign an IPaddress for IPsec “Dial Up” users. In the Fortigate logs, I get a “peer SA proposal not match local policy”, obviously because I only created an IPSec peer, and no IPsec Policy on the Mikrotik… just not sure how to create a policy when there’s no routed subnet… the remote router is supposed to send me a dynamic IP in phase 2 (on the fortigate, the phase 2 policy is set as 0.0.0.0/0 to 0.0.0.0/0 assign client IP pool 10.10.100.20-10.10.100.200.
