I can’t use btest with fresh 6.44.3 ROS - it just disconnects.
When I try to run bandwidth test from older ROS (6.42) to 6.44.3 - it also doesn’t work (2+ tcp conections - ‘test unsupported’, 1 tcp connection - client just disconnects with no error), so it seems like there’s protocol change which breaks old clients.
How can I run bandwidth test from PC to ROS 6.44.x? Is updated btest available somewhere? Or mikrotik will not support anymore bandwidth test between MT and PC?
