When configuring ROS 6.6 so that one interface has one static ip and one ip from dhcp (both in the same subnet) - after a week the interface stop responding to any packets.
Status in the routing table for 0.0.0.0/0 route is “unreachable”. But pinging the gateway from the router does get reply.
This router was set up with no firewall nor nat-rules.
Rebooting the router does not make the interface start responding.
When deleting either the dhcp client or the static ip, the interface starts responding again.
The changelog for ROS 6.6 states something related to multiple IP’s, so I’m thinking this is an ARP-update failure that might have been introduced with the new ROS.
However, if the issue was an arp-failure, I’d expect that restoring the config that was running for a week would make the config run for another week - it didn’t. Restoring the config from backup puts the interface dead immediately.
Does anyone have a clue what may cause this behavior?
