[quote=woqup5s0wf post_id=760339 time=1573670196 user_id=151008]
Dear Mikrotik team,
it seems you have enabled 64-bit support on the x86 platform. The command /system/hardware/print shows:
</s>multi-cpu: yes
allow-x86-64: no<e>
If you enable 64-bit support and reboot it correctly enables it, see the memory:
</s> uptime: 2m20s
version: 7.0beta3 (development)
build-time: Oct/22/2019 09:34:17
free-memory: 3860.7MiB
total-memory: 3904.0MiB
cpu: Intel(R)
cpu-count: 2
cpu-frequency: 1166MHz
cpu-load: 0%
free-hdd-space: 110.8GiB
total-hdd-space: 110.8GiB
write-sect-since-reboot: 424
write-sect-total: 424
architecture-name: x86_64
board-name: x86
platform: MikroTik<e>
But if you do that the wireless support gets disabled, so I guess it isn’t actually supported. Here you said it shouldn’t be possible to enable it on the x86 platform.
Thanks!
[/quote]
Here is me screen for x86 whit activate 64 bits
