Ros 7.14
Can anyone help me with 2 thing on v7?
-Multicast helper howto in wifiwave2(totally not found in v7,capsman)
-Multiple ssid without vlans,wifiwave2,capsman.
Thanks;)
https://help.mikrotik.com/docs/pages/viewpage.action?pageId=46759946#WifiWave2(7.12andolder)-CAPsMAN-CAPsimpleconfigurationexample:
Thanks,this solved. The key was at CAP,wifi/cap/slaves static must set to yes,after that it appeared in capsman as an interface.
The big question is multicast helper onwards. Not found it on capsman and 7.14sw
