RoS 7.15 broke a DHCP script
I am using a script that is run on each lease change and it worked quite well up until 7.15. It tries to get the MAC vendor from the lease MAC and set it as a comment.
I am unable to find anything in the changelog pertaining to this issue.
The only thing I can see is
fetch - changed topic "info" to "error" for permission denied logs;
, but I cannot set any permission for the script on DHCP server.
The script:
:log info ( . "Hostname: " . ([/ip dhcp-server lease get [find active-address=$leaseActIP] host-name]))
if ($leaseBound =1) do={
  local result ([/tool fetch url=("https://api.macvendors.com/".$leaseActMAC) output=user as-value ])
  if ($result->"status" = "finished") do={
    local comment0 ("MAC Vendor: ".$result->"data")
    ip dhcp-server lease set [find mac-address=$leaseActMAC dynamic=yes] comment=$comment0
The error:
executing script from dhcp failed, please check it manually
Anyone knows about a 7.15 change that might stop this script from running properly? As in why the error, as the MAC is obtained and inserted in the comment.
later edit: it seems creating a separate script and calling the script from the DHCP server instead of running the whole script there got rid of the error.
Thank you
please use the official topic about 7.15
http://forum.mikrotik.com/t/v7-15-3-stable-is-released/176334/1
Try to use this:
#-----------------works----------------
:if ($leaseBound =1) do={
    local comment0 ([/system clock get date]." | ".[/system clock get time]." | "."MAC Vendor: ".$result->"data")
 /tool e-mail send to=your@mail.com  subject="DHCP-List-LAN" body="$leaseActIP - $"lease-hostname" - $leaseActMAC - $comment0"
if you don’t need send it to email, remove the whole line 7.
ideal save it as script, like dhcp-lan-lease-script and put it in
ip/dhcp-server/add lease-script=dhcp-lan-lease-script
permissions for the script must be ftp,reboot,read,write,policy,test,password,sniff,sensitive
