Hello!
I’m trying to create a guest wlan in ROS7 (did that before in ROS6 with/without capsman, all good).
# 2024-06-12 18:37:07 by RouterOS 7.15.1
add name=lan-bridge vlan-filtering=yes
/interface vlan
add interface=lan-bridge name=guest vlan-id=10
add interface=lan-bridge name=lan vlan-id=100
add name=Gateway
/interface wifi channel
add band=5ghz-ax disabled=no frequency=5220,5180-5320,5660-5845 name=5ghz \
skip-dfs-channels=10min-cac width=20/40/80mhz
/interface wifi configuration
add antenna-gain=0 country="United States" disabled=no name=home-private-cfg \
security.ft=yes .ft-over-ds=yes ssid=MikroTik-Home tx-power=30
add antenna-gain=0 disabled=no name=guest-cfg ssid=MikroTik-Home-Guest \
tx-power=30
/interface wifi datapath
add bridge=lan-bridge disabled=no name=home-private-datapath vlan-id=100
add bridge=lan-bridge client-isolation=no disabled=no name=\
home-guest-datapath vlan-id=10
/interface wifi security
add authentication-types=wpa2-psk disabled=no management-protection=disabled \
name=home-private
name=guest
/interface wifi
set [ find default-name=wifi2 ] configuration=home-private-cfg \
configuration.mode=ap name=wifi-2.4ghz security=home-private \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel=5ghz configuration=home-private-cfg \
configuration.mode=ap disabled=no name=wifi-5ghz security=home-private
add configuration=guest-cfg configuration.mode=ap disabled=no mac-address=\
D6:01:C3:9D:86:32 master-interface=wifi-5ghz name=wifi-5ghz-guest \
security=guest
add name=lan ranges=192.168.100.2-192.168.100.254
add name=guest ranges=192.168.10.2-192.168.10.254
add add-arp=yes address-pool=lan interface=lan-bridge name=lan
add add-arp=yes address-pool=guest interface=guest name=guest
/interface pppoe-client
add disabled=no interface=ether5 name=ISP profile=default-encryption user=\
v41012953
add bridge=lan-bridge interface=ether1
add bridge=lan-bridge interface=ether2
add bridge=lan-bridge interface=ether3
add bridge=lan-bridge interface=ether4
add bridge=lan-bridge interface=wifi-5ghz
add bridge=lan-bridge interface=wifi-2.4ghz
add bridge=lan-bridge interface=wifi-5ghz-guest pvid=10
add address=192.168.100.1/24 interface=lan-bridge network=192.168.100.0
add address=192.168.10.1/24 interface=guest network=192.168.10.0
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=192.168.10.1
add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1
set allow-remote-requests=yes doh-max-concurrent-queries=150 use-doh-server=\
https://8.8.8.8/dns-query verify-doh-cert=yes
add action=accept chain=input connection-state=established,related
add action=accept chain=input in-interface=lan-bridge
add action=drop chain=input
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward in-interface=lan-bridge out-interface=ISP
add action=drop chain=forward
I’ve tried both setting vlan through datapath, config posted has interface added manually to bridge. The problem is I can’t connect to the secondary SSID from android (shows connect failed) or PC (connects but can’t get address). Where did I fail in config?
You have to make guest interfaces static and manually add them to bridge and filter them in vlan filtering.
As such:
/interface wifi cap
set discovery-interfaces=vlan241_mgmt enabled=yes slaves-static=yes
New ax devices able to grab datapath from capsman and use vlan settings from capsman. Older devices qcom have to use local datapath on cap.
add bridge=bridge1 disabled=no name=bridge1
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether1 internal-path-cost=10 multicast-router=disabled path-cost=10
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether2 internal-path-cost=10 path-cost=10 pvid=242
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=wifi1 pvid=240
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=wifi2 pvid=240
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=wifi15 pvid=247
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=wifi16 pvid=247
As such:
/interface wifi cap
Thanks for reply, device is hap ax3 without capsman. With datapath specified, when I try to connect, I see dynamic wireless interface with pvid 10 in /bridge/ports and dynamic “current tagged” vlan10 in bridge/vlans.
Like I said dinamic bridging with vlan filtering isn’t working great with capsman2 currently. If you’re using vlan filtering - use static interfaces for wlan and bridge\filter them yourself.
Yes, I’ve added them statically. Here’s current relevant configuration
/interface vlan
add antenna-gain=0 country="United States" disabled=no name=home-private-cfg security.ft=yes .ft-over-ds=yes ssid=MikroTik-Home tx-power=30
add antenna-gain=0 disabled=no name=guest-cfg ssid=MikroTik-Home-Guest tx-power=30
/interface wifi
set [ find default-name=wifi1 ] channel=5ghz configuration=home-private-cfg configuration.mode=ap disabled=no name=wifi-5ghz security=home-private
add configuration=guest-cfg configuration.mode=ap disabled=no mac-address=D6:01:C3:9D:86:32 master-interface=wifi-5ghz name=wifi-5ghz-guest security=guest
add bridge=lan-bridge frame-types=admit-only-untagged-and-priority-tagged interface=wifi-5ghz-guest pvid=10
/interface bridge vlan
add bridge=lan-bridge untagged=wifi-5ghz-guest vlan-ids=10
So all interfaces (wlan and vlan) bridged, guest-vlan has dhcp server and IP on it, no success.
Is that all you have in vlan filtering settings? And where should your AP send tagged traffic then?
There’s an interface in /interface/vlan it should go there, no?
