ROS 7.1beta2 - routing via Wireguard
I’m trying to route all traffic for one lan IP over Wireguard. I’m just a little confused, because there was some changes related to routing etc.
I have working wireguard interface, I can ping it from Mikrotik, or from my local PC (I added masquerade, in order to use wireguard server as DNS source - this is also working fine).
I was trying to make this config, but it doesn’t work:
/routing table add name=via-wg fib
add check-gateway=ping distance=10 dst-address=0.0.0.0/0 gateway=wg_01@main routing-table=via-wg
Ok, so I was able to make it run:
/routing table add fib name=via-wg
/ip firewall mangle add action=mark-routing chain=prerouting src-address=192.168.88.200 new-routing-mark=via-wg
/ip firewall nat add action=masquerade chain=srcnat out-interface=10.13.13.3 // my local wireguard IP
/ip route add gateway=10.13.13.1@main routing-table=via-wg  // remote wireguard IP
The problem is, that with fastrack enabled it is not working - DNS and ICMP (ping) is working fine, but I’m not able to use browser (even after clearing cache). Any ideas?
Fasttrack skips a lot of processing, including prerouting mangle, so what you’re doing is incompatible with it. If you need it for static address, you can use routing rule instead. Or you could mark connections instead of directly marking routing, then mark routing based on connection mark, and only fasstrack packets without this connection mark.
Ok, so in that case it will be:
/routing/rule/add src-address=192.168.88.200/32 action=lookup table=via-wg
It is working with fasttrack, thanks!
I used mangle, because I will have different types of connection, which I want to pass trough VPN. Constant IP is only a start. What do you suggest in that case?
Previous post, last sentence. :slight_smile:
