I’m using several MT devices on local network:
1-CCR1009-7G-1C-1S - Main router
2-wAP G-5HacT2HnD_A - First AP
6-RBwAPG-5HacT2HnD.rif - Second AP
3-RBSXTR - LTE Modem - Backup internet
5-CRS305-1G-4S+ - 10G Switch
7-RBwAPR-2nD - Lora Gateway
Everything was working corectly on 6.49.5. I’ve made manual upgrade to ROS 7.2 all devices except main router ( CCR1009-7G-1C-1S+ ) and then main router starts behave abnormally. It starts loosing 50% packet on almost every port. So I’ve upgrade it to RoS 7.2 but it doesn’t fix the problem.
Problem gone when I’ve phisically disconnect almost every MT device from list ebove ( except 2-wAP G-5HacT2HnD_A ). After reconecting again, problem has returned.
What is more interesting, SFP+ port which was connected to QNAP 10G also behave strange. Please check attached video. You will see that value in field ‘Connector Type’ and OM4 disappear for a moment. For test I’ve also connect this port to another CRS305-1G-4S+ using MT DAC but it behave in the same way. Both value in fields disappiring for short time periodically.
I didn’t make support file from this situation, couse I thought that router has been damaged. Fortunetelly downgrade all devices to 6.49.5 restored proper netowrk working on 1-CCR1009-7G-1C-1S+
support file for all above MT devices was send to support@mikrotik.com. but from situation when everything works normally ( from 6.49.5 )
I have no idea what may couse such problems. I’m using also dude server on CCR1009-7G-1C-1S+
Is support file from problematic situation will be required, I will try to once again upgrade most devices to 7.2 and reproduce above situation.
https://drive.google.com/file/d/1DnUFZfsaVY9iPrRhuqeTk2EjThbOAvD6/view?usp=sharing
