ROS-7-xxx-Dev--X86-64Bit-BGP
Still need add BGP routing, For test.
When believe can add this function ?
thanks
It’s still beta. They are testing function by function. There will be no set date. Wait until first release candidate if you want feature parity to ROS6 , ROS7 beta’s will likely go for a long time.
know if next update, include some BGP option ?
thanks
I am anxious to test this as well. There are a number of things in BGP that v7 is supposed to fix/improve.
Hopefully we’ll see a new RouterOS v7 in February with BGP added :slight_smile:
